1 - 4 of 4 Posts
I finally finished my basement, so now I need a 2nd receiver. After reading all the comments on the horrible quality of the coax/HPNA interconnects I really want to use an RJ45 connection between the receivers.
A few questions that I'm hoping you guys can answer before I talk to MTS and prewire the required connections:
  • Does MTS have to install the box or can I do it myself
  • How does the Cat 5 interconnect work? Can i hook it into my own network switch (which is connected to the 2wire) or does it have to go directly into the gateway
Did you see this thread? It includes a couple of switches. My Home Network including MTS TV.
I can offer educated guesses to your questions.
I doubt MTS will let you do a self-install. They probably don't have the procedures in place to do that. I tried to do that with MTS Classic when all the wiring was in place from a previous install and they wouldn't do it.
If you have RG6 coax and properly installed connectors you shouldn't have a problem. Just insist that the installer does the HPNA test like he's supposed to.
Officially, MTS will probably consider a network with customer-provided switches as unsupported. If you pre-wire your basement with Cat5, the installer will likely use what is there, whether there is a switch there or not.
thanks for the link Dr. Dave, I'll post here again when I get the 2nd receiver with results. I've got network jacks all over the place so I'll definately be pushing the installer to utilize them.
cat5 to 2nd mts reciever
there are only 4 ports on the mts 2wire ( the wireless router & modem for both tv & enet ), 1 port is needed to feed the pvr with cat5 , and the remainder for internet devices, coax will work fine ( cable companys use it for their high speeds ;)) as long as good compession connectors are used , dont use copper braided coax .....strive for direct runs , but if splitters are necessary use HPNA grade splitters and high grade inline connectors
1 - 4 of 4 Posts
