This is a thread just for the discussion and postings of known locations of capacitor failures on Bell TV Satellite Receivers. If you post in this thread you should include the model of the receiver, the capacitors locations (ex. C393), voltage of the capacitor (ex.10V) and capacitance of the the capacitors (ex. 10 uF rating)
Known issues:
(6141)
C440 - 820uf 6.3V
C78 - 820uf 6.3V
C762 - 2200uf 10V
C43 - 100uf 10V (added after post 9)
C44 - 100uf 10V (added after post 9)
(6400)
C64 - 820uf 6.3V
C141- 820uf 6.3V
(9241)
C152 - 820uf 6.3V
C164 - 820uf 6.3V
C272 - 820uf 6.3V
C273 - 820uf 6.3V
C944 - 2200uf 10V
C929 - 1200uf 6.3V
C355 - 1200uf 6.3V
C288 - 1200uf 6.3V
C309 - 1200uf 6.3V
C24 - 100uf 10v (orange) - lift off metal cover over satellite tuner to access
C39 - 100uf 10v (orange) - lift off metal cover over satellite tuner to access
(9242)
C375 - 680uf 10V
C393 - 680uf 10V
C282 - 820uf 6.3V
C286 - 820uf 6.3V
C338 - 1200uf 6.3V
C419 - 1200uf 6.3V
C439 - 1200uf 6.3V
Typical symptoms you may see: freezing, lagging, pixelation, unresponsive remote, or slow to change channels (more then 4-5 seconds) and/or random reboots or constant cycling (reboots it self indefinitely)
NOTE: It is also possible your INTERNAL Hard Disk Drive may have failed (Applies to the 9200/9241/9242/9400), but that isn't typically the case. So if you do change all your caps ensure you can playback one of your first recordings and last recordings to ensure all is well with your Hard Disk Drive. If you are unable to boot back up after changing them you may have a Hard Disk issue/failure.
Any additions or if something is missing please submit them here or PM me. Thank you hopefully this helps someone in the future.
Known issues:
(6141)
C440 - 820uf 6.3V
C78 - 820uf 6.3V
C762 - 2200uf 10V
(6400)
C64 - 820uf 6.3V
C141- 820uf 6.3V
(9241)
C152 - 820uf 6.3V
C164 - 820uf 6.3V
C272 - 820uf 6.3V
C273 - 820uf 6.3V
C944 - 2200uf 10V
C929 - 1200uf 6.3V
C355 - 1200uf 6.3V
C288 - 1200uf 6.3V
C309 - 1200uf 6.3V
(9242)
C375 - 680uf 10V
C393 - 680uf 10V
C282 - 820uf 6.3V
C286 - 820uf 6.3V
C338 - 1200uf 6.3V
C419 - 1200uf 6.3V
C439 - 1200uf 6.3V
