1 - 13 of 13 Posts
I was recently told that Shaw can tell if the New 600 receivers are not at one location. Something about each receiver has an lnb assigned to it?
Does anyone know if this is true?:confused:
I think if your activated receivers don't have the same v-code on them then they can tell you are using them in 2 different locations and could deactivate your account if you don't pay the extra home and away fee.
Not any more than any other receiver.
The LNBFs, that I know, are dumb, they just down convert satellite RF to coaxial RF, more or less.
The receivers could ping the provider over network, or modem if equipped, to see where they are pinging from. With no connection, SD is none the wiser where the receivers are.
Discussion Starter #5
Thanks for everyone's reply.
I just want to know with the New technology of the New 600 receivers if they can tell if your receivers are not at the assigned LB'S that were assigned at activation.?
Any more replies would:rolleyes: be much appreciated.
They aren't assigned to a particular LNBF, just set so they work from particular type of LNBF, and for certain channel maps based on location and circumstance.
The LNBFs have no individual identity, nor any intelligence involving satellites or the receivers.
All the new technology of the 600 series is really MPEG4 and the network port, nothing to do with the satellite side of things.
Is that clear enough?
Basically if you have the new xKU LNBF where you activated the 600, you need to have the same xKU LNBF at any other location you take the 600, otherwise you will loose channels.
This can be corrected by calling Shaw and telling them the type of LNBF at the 2nd location but then if you take it back to the 1st location, you would have to call Shaw again, as the Channel Map will need re-setting.
Best to use the same LNBF at all locations, makes life easier all round.
There are two ways they can track receivers. One is if the receivers are connected to a phone line. This is common for automated ordering of PPV. The other is if they are connected to the internet through the LAN connector. This is commonly done for Shaw's VOD service.
It's not clear whether Shaw actively tracks receivers. Bell does track receivers and calls customers to verify the location of receivers not connected to a phone line. I've never heard of Shaw doing this.
In theory, GPS locators could be built into satellite receivers (similar to phones and tablets) but I've never heard of this being done.
Only if you plug it in to a phone line or connect to your LAN by wire or in the case of the 8xx by wifi.
If you have multiple receivers they may call to verify your receivers asking for Unit IDs.
As gzink said - a receiver is only a receiver unless you connect it to something that has transmit capabilities to the outside world like a phone line.
Using wifi is more common on newer receivers. With the 600, connecting with ethernet to get VOD will register the receiver in the same way as a phone line. Some newer receivers communicate with each other so connecting one will register them all. Don't know if the 800 series does this.
1 - 13 of 13 Posts
