Status
Not open for further replies.
1 - 6 of 6 Posts
I upgraded to a Bell 6131 and am having a hard time finding Bell 82 to get the HD channels. I have another bell dish and was wondering if I can pick up one satellite on each dish ? When I look around I notice a lot of the Bell dishes the elliptical runs closer to Parallel whereas my ******** dish the elliptical is closer to vertical ??
Installation of Bell dishes and equipment is already covered in other threads and in the receiver manual. Yes, you can use two dishes but it should not be necessary, especially in central Canada.
There were dish installation instructions in the front of the manual. Maybe that has changed. Values for aiming the dish can be found here. It sounds like you need to adjust skew on the current dish. There are a number of threads that describe how to troubleshoot common problems as well.
Discussion Starter · #5 ·
I don't see any way of adjusting the skew of my current dish, that's why I was wondering about using 2 dishes - looks like 82 is up and left of the 91 signal ?
· Member #1
As noted by ScaryBob, The answer to your question is Yes.
This forum is loaded with Sticky threads discussing all manner of implementation. Please use them and ask questions in an existing thread.
1 - 6 of 6 Posts
Status
