1 - 2 of 2 Posts
Hi,
I'm using an iPhone 4 and try to find a VoIP provider with an acceptable audio quality under quite strict constraints.
I ran a spped test and here're my results:
Ping 294 ms
Downloading 0.34 Mbps
Uploading 0.13 Mbps
Is there an effective VoIP related codec which enables satisfactory VoIP communication? If so, which application provides the good?
1 - 2 of 2 Posts
