1 - 7 of 7 Posts
I am interested in putting a couple of powerline adaptors in the house.
Since all the Ethernet ports on my router are currently in use, I was wondering if I could just plug an adaptor into one of my network switches and then plug another adaptor where I need it.
I seem to think I can but thought I should ask before buying.
Thanks in advance
Hugh
That's not what I'm asking though. I don't want to plug an adaptor into the router. I want to plug the adaptor into a switch.
I'm 99% sure it will work but I would welcome confirmation that it would.
Yes, you can have one connected to your switch and one or more remote adapters. Check the specs for the various units to verify. Canada Computers has a few models.
Discussion Starter · #7 ·
Thanks for the confirmation.
1 - 7 of 7 Posts
