1 - 8 of 8 Posts
I am looking to build an OTA but the TV transmitters appear to be spread out in a wide range of angles. I was wondering if I can combine multiple SBGH antennae facing different directions?
Or, will a quadruple SBGH antenna work at all? That is, a contraption that has 4 antenna's facing 4 directions, combining into a single output. Two opposing antennas will share the grid reflector and have their own bowtie assembly.
Any comments on how this will/will not work?
Please post your TvFool . It`s a very important tool for determining what design might work best for your location. You may not need multiple antennas for the results you`re after . If your transmitters are within 60 miles I have plans for a multi-lobed GH that is working perfect in two different locations ( both ends of Lake Erie ) covering scattered markets without the use of a rotor.
Anything above channel 8 (8.1) should be easy to catch with a single SBGH, except maybe the VHF channels. Everything is LOS and in the northern direction.
To get the VHF channel, I'd sugget you use the version with NAROD.
Right now, I'm picking up channels at real channel 23 at 70 degrees from where the SBGH points to with a NM of 0.4 from an attic instalation (I don't beleive it either...)
jf
Discussion Starter · #7 ·
Thanks everyone
Antenna is complete and I receive about 60 channels, including the network channels Fox, ABC, CBS, NBC, NPR... So it was pretty much a success.
I decided to design the SGBH with NAROD.
One funny thing, ABV (7-1) reception was non-existant with the simple SGBH, excellent with a single NAROD in the bottom and bad with top and bottom NARODs. I dont know why, but anyway, I decided to go with a single NAROD at the bottom.
1 - 8 of 8 Posts
