1 - 3 of 3 Posts
Can anyone tell me how I can remove this lock/bolt. I do not have the slightest clue of what wrench i can use or what type of tool i can make to remove this bolt with out damaging the box.
The bolt has two semi circle slits around a circular hole. The circular hole is approximately half an inch deep where there is a brass looking bottom.
1 - 3 of 3 Posts
