1 - 9 of 9 Posts
Almost all cell phones are locked to a specific carrier, which means a SIM from another carrier will not work. You'll have to research if this phone can be unlocked and how. Once you do that, you'll also have to figure out how to get O/S updates as Rogers won't give them to you.
Finally, a phone made for any carrier besides AT&T might not work with Rogers perfectly. For example, you might only get Edge instead of 3G for data.
Phonearena.com shows the UMTS (3G) frequencies for the HTC Desire HD to be 900/2100 -- however, for Rogers they are 850/1900. You'd probably have better luck with connecting that phone to Telus or Bell HSPA networks.
Not true. Bell and Telus use the same HSPA/UMTS frequencies as Rogers (850 & 1900). Here's the breakdown for compatibility.
AT&T -> Rogers/Fido/Telus/Bell (all with 3G support
T-Mobile -> WIND 3G / Rogers & Fido 2G only (EDGE)
Sprint -> None
Verizon -> None
Sprint and Verizon use CDMA technology, and while Bell and Telus do also have a CDMA network, they will not activate such a device from another carrier.
WhitbyTerry is correct that the phone would need to be unlocked first as well.
Not true. Bell and Telus use the same HSPA/UMTS frequencies as Rogers (850 & 1900) ...
Thanx for clarifying that HSPA uses the same frequencies as UMTS.
So ... you're saying that even if this phone is obtained unlocked, 2G and EDGE is the only support the OP will find in Canada for this phone(?)
Premium Member
As far as I know this is a European only phone. The version sold in Europe will not be 3G compatible in Canada, you could use for for 2G service only on Rogers/Fido/Chatr.
If an American carrier has it then it likely has different frequencies and that version might work, but to my knowledge no American carriers have it yet.
While Rogers won't give them to you, they're still available from the original source. I've received a couple of Android updates from my Google Nexus One, as well as several app updates.
Premium Member
That's because your Nexus One supports HSPA 850/1900. The Desire HD which the OP was referring to does not. Thus, only 2G GSM/EDGE would be available in Canada.
Unless a different version is released (like the original Desire), no Canadian carrier will support 3G on the HTC Desire HD. Only Rogers/Fido/Chatr can support it in 2G.
Updates would still be available, but they may not come OTA, and you would be at the mercy of a carrier in another country to release it. The Nexus One is different in that updates come directly from Google. At the moment, all other phones must pass manufacturer and then carrier certification.
1 - 9 of 9 Posts
