Status
Not open for further replies.
1 - 2 of 2 Posts
I have an 8642 PVR and wondering if there is an Ethernet Network connection to the computer and if I can see the concerts on my HDD would I be able to burn DVDS on there. Right now it is a 160 GB HDD and it is almost full since everytime I want to PVR another program it gives a warning....low recording space. Do they have any connection of such? Thanks in advance.
This has been discussed numerous times on this forum. You have the following options:
1. DVD recorder.
2. Hauppauge HD PVR on an HTPC.
3. Possibly firewire to HTPC, depending
Here's the sticky on the topic - see the various links in post 1, please use that thread if you have additional questions, or the Hauppauge or Firewire threads, as applicable:
http://www.digitalhome.ca/forum/showthread.php?t=50162
You may wish to consider an external HDD or increasing the size of your internal - stickies on that also in this forum.
1 - 2 of 2 Posts
Status
