Hi folks,
Long story short, I am trying receive a RF10 transmitter that is 3 miles away but only 100 watts. Getting RF8 is a secondary objective, but that station is operating at 3kW from the same antenna farm and is easy to receive reliably. The RF10 signal is only one very small spot, in the corner of the attic, touching the roof, and the best success I've had is the Antenna's Direct VHF kit simply because it's small enough to fit where the signal is.
Attached pictures show the space I'm working with. The new antenna needs to be at least be as high as the current VHF antenna to get signal. The 2x4's make a rectangular area around roughly 23"x 25". Ideally would like to avoid going behind the 2x4's, as it that does make aiming more complicated and I suppose can lead to signal loss.
The bigger antennas I've tried (ClearStream 5, YA7000) get worse signal quality because they do not fit. With the AD VHF kit, I get a steady 98% signal quality most of the time, but still gets some drop outs at randomly. I suspect being in the attic, there is multipath and other household interference that might be mitigated somewhat by installing an antenna that has more directionality and gain than a simple dipole.
To summarize, my goal is for the new antenna to have more gain and directionality vs the AD VHF dipole kit, but small enough to fit in a small footprint.
I have a few ideas, but would love some input:
- Off the shelf VHF antenna modified to fit
- Stellar Labs 30-2475 Fringe VHF - If I cut remove the top reflector and cut it in half, I could make it fit
- Two piece RCA ANT751x with the UHF portion of the boom removed
- Televes 106501 cut in half
- Televes 106601 cut behind the dipole
- DIY dipole specifically for channel 10. The AD VHF kit is 35 1/16" wide. A dipole calculator says a 195 MHz dipole would be 28.8" wide. I don't think this would buy any more gain than the current AD VHF dipole, but due to the angle of the roof, I could move it up slightly - maybe another inch or so
- DIY 2 or 3 element Yagi designed for 195MHz (inspired by First Post, DIY VHF Hi Yagi)
- The wireantennas.co.uk calculator spits out a 30"x8" 2 element yagi and a 31"x16" 3 element yagi
- The Chang Puak antenna calculator spits out a 33.6" by 19.4" 3 element yagi
