Status
Not open for further replies.
1 - 5 of 5 Posts
I am looking at the ability to play mostly music from my PC to my home entertainment system. The secondary stuff would be pics and then the net. I have a wireless router along with an ethernet connection by the entertainment system. What are my options and what products can you recommend.
if you use itunes, i think the cheapest audio only would be an airprort express. this little device is both a wireless access point as well as an audio device. you buy a cable that plugs into the unit and outputs into l/r audio connectors which in turn go into your receiver. you then control it through itunes or from your iphone/ipod touch. very nice device under $100. or if you want movies, pictures, music, etc. then you need a network streamer which are a dime a dozen. apple makes one known as the appletv which is pretty good for its price, although your files need to be compatible with its (apple) formats.
The Playstation 3 can access multimedia files (video, music, etc) from Windows Media Player running on a PC on your network via wireless (or wired). You would get the ability to play Blu-Ray movies with this option as well (if you don't already have that).
I expect other game systems might do this as well.
waketech, this question has been asked a ton.
Please search the forum for many discussion threads on various media streaming devices such as PS3, XBOX 360, Roku, SoundBridge, Scirocco, Squeezebox Buffalo, and Apple TV,
Company's also makiing media streamers include NetGear, Dlink, LInksys, Sony, Logitech and more.
1 - 5 of 5 Posts
Status
