1 - 3 of 3 Posts
Discussion Starter #1 (Edited)
I've bought a new active speaker (yamaha msr 400)
it is bi-amp
can i add a passive subwoofer?
without amplifier. just use the build-in amp of my active speaker?
if yes, how can i do that?
and if not, what are the options with a 'bi-amp' speaker?
thx
I wouldn't use the built in amp. It is designed to drive just the one speaker in the cabinet. A powered sub would be much better. There are lots of sub recommendations in other threads. You could also check out the MSR800W. Only one sub would be needed.
Discussion Starter #3
Yes, you are right, but bi-amp isn't ment to use 2 speakers on the same build in amplifier?
oké, are there any very cheap powered subwoofers??
thx
1 - 3 of 3 Posts
