Yes. You would want to make something like that out of the UV resistant electrical pvc and its also cheaper to boot.Would a 6 foot tripod-mouted mast made of ABS of PVC be less likely to be struck by lightning than a metal pole?
Yeah, I used that stuff on my first build last year. The PEX tubing sold at Home Depot or Lowes specifically says its not UV resistant, so youll have to paint it for protection. Also the 3/8" ID stuff is a little smaller than the 3/8" typical antenna element, so I had to drill it out a little IIRC.I tried PEX tubing ( used for water supply lines ), purchased from a home center. PEX comes in different variations, some are advertised as UV resistant but you would probably have to look that up on the web.
Maybe I didnt understand what you are saying but carbon fiber for spacers will conduit elec depending how it is coated but I'm sure everyone know that.Yeah, when searching for some plastic or carbon fiber tubes for colinear rod spacers, also think in the other direction if using tubular aluminum.
The ones above dont, but then again, maybe they are really just black fiberglass, hard to tell with chinese plastics. I always check with a meter. I guess I should have mentioned those tent poles were from a cheapie 2 or 4 person mountain tent set, heh.but carbon fiber for spacers will conduit elec depending how it is coated but I'm sure everyone know that.
On the label it says "Lasts season after season" heh.I wonder how good the UV protection really is.
I bought some rigid plastic tubing at a model building store. They weren't too sure of the material, but it was fairly rigid and good for non structural parts and came in a huge variery of diameters, I think they had from about 1/16" up to 2", with about 40 sizes in between, no exaggeration. The place I went to specialized in tiny materials for building doll houses, train models, etc...rigid PVC 1/4" tubes, to support the gap between reflectors in a GH10 or DBGH
For some reason these are EXTREMELY hard to find in Canada (impossible for me north of Toronto, anyway). I looked in 5 stores and the only kind anyone had were the aluminum folded sheetmetal ones. I don't know if it's because they don't stand up to the cold winters, or maybe it's just not a common practice in this area, but they don't seem to exist around here.grey UV resistant plastic gutter ferrules
Sounds good to me too ! I used to use 3/8ths inch Lexan on my boat windshields, because at that thickness, it was almost bullet-proof and my friends butt couldnt break it, unlike plexi, heh.... and at a fraction of the cost of lexan, making it a very good choice for my application.
