Just a warning note about using ABS for structural parts that I've mentioned many times before - hopefully what you're planning to use is the thick walled stuff that has little or no flex. If you go to Rona or Lowe's or Home Depot and shake a 10 foot ABS pipe like a sword it flexes a lot.
It seems to be rigid, but its not. If you shake a length of PVC like that it will seem like a wet noodle, so avoid using PVC for structural use either, except when recommended in build plans.
From experience I'm clarifying that ABS should never be used as a pole or mast, and it should be carefully considered if you're thinking of using it as a horizontal boom of any length more than a meter or a few feet.
