1 - 4 of 4 Posts
Hello, i have bought my PS3 recently and now i am thinking on buying a HDTV to enjoy my PS3 100%, i have been caming across some issues like input lag, the hertz of TV's and some other things, so i came here to ask for help.
The Main qualities i expect on a Good HDTV are:
Screen size of 32' to 40'
Very Low input lag
60 hertz or more
1080P resolution
No burn in
No Motion blur
screen resize function
Game mode function
Long Lifetime
I Also don't know yet very well which is the best type of TV for gaming, is it Plasma, LCD or LED?
My Budget is something of 500€, so if anyone can tell me what is the best HDTV for gaming with a budget like that i will be very appreciated.
Thanks in Advance.
I would do a google search for TVs with good input lag results. For LCDs I've read that the IPS panels are the best. Dell uses IPS panels on their best monitors. The only TV makers that I know of using IPS panels are LG and Panasonic but beware, manufacturers sometimes change their panel sources and that is only one aspect of finding a good gamer TV.
1 - 4 of 4 Posts
