Re-set receiver
You can re-set your receiver by following the steps for your model type.
Models 3100, 4100, 3200, 5100, 5200, 5800, 5900, 6100, 6141, 9200 and 9242 -follow these steps:
- Press and hold the POWER button on the front panel of your receiver until the green light turns off. Once the green light has turned off, release the POWER button.
- Wait for the signal acquisition process to be complete (you should see Attention screen 015 on you TV screen).
- Once the signal acquisition process is completed, check to see if your programming has returned.
Models 1000, 2700, 3700, 3500, 4500, 4700 - follow these steps:
- Locate your receiver's SmartCard. It's located at the front of the receiver to the far left. Depending on your model, it's either exposed or behind a plastic cover panel that flips up or down.
- Remove the SmartCard from your receiver and wait until you see the System Information Screen.
- Re-insert the SmartCard. Be sure the bar code is facing down and to the right. An error message will appear on your TV screen if the Smartcard is not inserted properly. The green power light on the satellite receiver will blink once and then stay on permanently.
- Wait for the signal acquisition process to be complete (you should see Attention screen 015 on your TV screen).
If channels are still unavailable, try the self-serve synchronize programming option at Bell's
Self Care.
