OK I had a U 760. All I got was at most 1mb/s and something like .5 mb/s up. But for a number of weeks I was getting very poor speeds. 0.5 mb/s down ! and only 0.06 up at times. I called Bell and they told me to install the newest driver Mobile_Connect_4.0. Then the old U 760 wouldn't work at all. The tech guy said get a new one. In the mean time I got a U 988, HSPA. Much faster but Bell is blocking ports that I want to use. And there is some sort of Data Compresion or something going on. SpeedTest.net reports 4.0 mb/s down but DSLports.com only reports a 1/4 of that???? Sounds kind of fishy.
So I got mad, uninstalled the new U 988 and put the replacement U 760 in along with Mobile_Connect_4.0 again. It's still almost as slow! And I see it is using HSPA ? What happened to EVDO ? Have they switched over and this may be why I'm getting the poor speeds? Maybe I should pull Mobile_Connect_4.0 out and put in the original software????
This is so frustrating. Telus is looking better and better all the time!
Mike
Mike
