1 - 2 of 2 Posts
Playing around with a cheap Android phone. Other than the completely disjointed messaging experience, it's not quite a truly terrible platform. However, there's no obvious way to have Visual Voicemail enabled.
Just not something supported by Bell?
It's not supported by Bell. Rogers, Telus, Koodo, Fido, and Wind support Visual Voicemail for Android. It would should up in the Dialer app as the forth button on the bottom (Favorites, Recents, Contacts, Voicemail). Also in the settings of the Dialer you would have the option to setup visual voicemail, but only if your provider had enabled it.
1 - 2 of 2 Posts
