541 - 560 of 600 Posts
Good find, although for some reason, Bell have been shipping Refurb 6141's for a while now, just being used on Rental Accounts to save 6400's I guess.
No one is connecting the OTA though and most Customers have no idea it is even there, especially the Customers in Apartment Buildings. What a waste of a good receiver.
I went out and purchased another 2tb seagate EHD, the same one I have on my 6131 and I noticed that the record time is off. It's saying that I'm only getting about 180hrs of HD space on the 6141 which is half of what my 6131 & 6400 gets. I'm assuming that it's just off.
Sounds like a glitch in the Software on the 6141.
Does it change if you put the same Drive on the 6131 or 6400 ?
Well I tried the HDD on the 6400 in the kitchen & it was the same 180hrs, I even went and checked to make sure it was the exact same 2tb drive I have on the 6131 and it is, so who knows what the issue is, not a big deal though as it won't have a lot of recording done on it.
I put on a brand new 2TB ehd on my 6141 yesterday and it only showed 180 hours of HD storage as well. After reading the posts above, it sounds like this is a software issue exclusive to the 6141. Disappointing as this is my 3rd full ehd! My 6131 has tonnes of room with a similar amount of recording.
Yes I could not get it figured out, as my 6131,6400's all showed 450hrs of HD on their 2tb EHDDS. If I had known this I'd have put it on one of the other receivers first to format it then tried it on the 6141.
Well sometime in the future I plan on moving my 6141 to the upstairs living room after I get my outdoor OTA setup so I can receive Global Regina in HD, then move my 6131 to were the 6141 was in the downstairs bedroom. I plan on leaving the HDD's were they are, so I will see if the EHDD stays with 450hrs of HD space. It should. The 6141 I bought was out of the stream for 3 years, maybe someone else that has had one going this whole time with a 2tb HDD can chime in and let us know if they are getting the full hours displaying?
Just a bit of an update... my new Seagate 2TB HDD failed within a couple days (don’t buy Seagate!) so I deleted a few things from my old full WD 2TB and voila! all of a sudden I had 190+ hrs of High Def recording space. So I gather this is all about compression and some of the old recorded programs taking up more space than new ones. Still doesn't explain why a brand new HDD only shows 180 hrs...
Question recently put on a Buffalo 1tb EHD on to a 6131. Can I watch one program and record a different one like my 9241 allows me to do?
Bell Receiver - 6140 - Loses signal the odd time
Folks,
So im having issues with a 6000 model receiver. Can't figure out why.
It will just lose sat signal, and if you do a check switch, it only finds 1 "channel" or whatever its called, does not see the switch, and fails.
Unplug for 20min or so, remove sat cable, and it comes back.
Setup:
Older SW44 switch. Switch is installed in the house (basement) Line 1, goes into the power adapter, then into this 6000 receiver.
I have a 9142 receiver as well, Line 2 and 3. No issues.
Cables aren't bend, ends are great, connection looks fine.
IM thinking, receiver is bad, or line on switch is bad. This possible?
If its a bad line, can i power the switch on line 2? and plug my 6000 receiver on line 4?
Or is it a bad receiver?
Any help would be appreciated, wife is driving me nuts. (her tv) hehe ;)
From what you are saying, you have a Bell 6400 (The 6000 has not worked on Bell for several years).
Have a look in the 6400 thread, there is a work around until Bell roll out new software.
@ fuzzai,
The Power Inserter must remain connected to Output 1.
Since the 9242 works good with outputs 2 & 3, try connecting the 6xxx receiver to output 4, and try another Check Switch test.
What is the exact Model #?
As Allan B, stated, the old Model 6000 receiver is no longer supported by Bell TV.
If you do have a 6400 receiver, some of these units are having problems similar to what you are describing.
I have a problem with OTA audio.
I was recording WUTV and my 6141 used the secondary audio channel with DV.
I can't seem to find how to change the audio channels for OTA.
I rescanned the channels and that didn't fix the problem.
And the audio selection in the SAT menu is only for BELL channels.
Any ideas?
if the firmware is anything similar to that of the 6131, i would press the * button on mine to toggle it on/off. hope this helps
