1 - 3 of 3 Posts
Hello!
I am new to this so please be kind if these are stupid questions. We have purchased a bell receiver 6131 a few months back and are having major troubles in setting it up. We have the dual LNB system with the internal switch. We have hooked up one end of our coaxial cable to #1 LNB. We than have it hooked up to our receiver. We have an HDMI cable connecting the t.v to the receiver and are able to get the satellite power bar on the screen but the only sat we can connect to is this US Echostar 110 West.
No matter how much we move the sat that is all we can connect to.
Can anybody help us?
L
Do you have the DPP Twin LNBF.? Will have the letters DPP in it.
As a new customer why not let Bell do the installation.?
To aim that LNBF I advise covering the 82 side with Duct Tape, then set the skew for your location, aim and peak signals on 91, then remove tape, run Check Switch.
1 - 3 of 3 Posts
