1 - 2 of 2 Posts
Hey all, new here. Just got Bell FibeTV and said good riddance to Rogers. I'm programming my fibe remote, but have noticed that there are no codes listed for my Sony blu-ray player, or any blu-ray player for that matter. I've tried doing a bunch of online searches for it, but havent turned up any useful information. Does anyone have (or know where to get) codes for blu-ray players so I can program my Bell remote to control it?
Much thanks.
· Super Moderator
I don't think the remote supports Sony's Blu-ray players directly. You could try the Sony DVD codes but I think Sony used a different code for Blu-ray so it wouldn't conflict with an existing DVD player.
You could also try the "Search" function described in the manual, although it's unlikely the code is supported.
The "Learning" mode should definitely work for just about any device. although it will take awhile to teach each button you want to use.
1 - 2 of 2 Posts
