1 - 3 of 3 Posts
Bell Fibe HD PVR playback freezes sometimes.
Has anyone else had this problem?
It has been happening quite often -
frequently with PBS Buffalo from which I record daily
the BBC News and the PBS Newshour .
But it has also happened on TVO and Vision.
I use Mediaroom on MTS and the PVR pauses occasionally - about once every 10 hours. The pause will be about 5 or 10 seconds. If I press the 7 second replay, the show segment will play without pausing, indicating that the PVR was probably busy. Once in a while when I press replay the program will pause in the same place, suggesting a corrupt signal.
1 - 3 of 3 Posts
