Bell sure must not want new business.
I spent 2 hours trying to order the new FibeTV service.
But sadly I was not able to.
I located in Toronto, in major area, I am only 1 minute walk from the local CO.
I have amazing FibeINTERNET service since the start, with solid 27meg down and 8meg up, with line tests showing 97meg down possible (since I am stone throw from the CO!)
But sadly "Customer Service" is almost IMPOSSIBLE trying to get FibeTV order, I said 90% of them don't even know what you talking about, the other 10% spent the most of the time transfering from line to line, asking for info, confirming info, and in the end giving you some for sure MAKE UP story to get you off the phone.
Here is the three basic stories I been getting from the 10% that know I ordering the new FibeTV service, the rest I just have to hang-up on and call again.
Story #1:
You need to be existing BellTV customer, the new FibeTV service is only available for those wishing to upgrade, and remove the DISH.
(I went as far as possible with this story, ordering the whole DISH setup, and getting an install date for the DISH tech, but cancel everything because I could not get confimed DATE for the switch to remove the DISH and go with FibeTV service)
Story #2:
To be able to get FibeTV, you need have a "dry-loop" installed, and your line must be able to handle the 25meg internet service already, we need to send out a "tech" to confirm that is possible, no problem, I explain I been a Fibe25 customer since GTA launch in Feb. 2010, and never have a line-drop or problem with the service. -- No problem, CS explains but TV is different service, we need to see if you can handle the new system, the call ends with the "fact again, I am not existing TV customer, so they can get a "tech" to confirm that I can have service, unless I become a TV customer first. (See STORY #1, get DISH first!)
Story #3
Great, I go thru the whole setup, give them mine ID, SIN #, do a credit check, confirm I can get service, have 2 TV's I wish to setup, order one PVR, another receiver, and ok $100 security deposit for the rental equipment, agree to 2-years, so no rental charges on PVR, but then I end with the call, when I get transfered because my DRY-LOOP line is not able to handle BOTH the FibeTV and Fibe25, if I wish to get TV, I would have DOWNGRADE my INTERNET service to either 6meg or 12meg with only ONE TV, even tho my "line-test" shows I am less 500meters from the CO, and can get 60meg or higher service.
THE END
So that is my END, I guess Rogers is stuck with me, I was hoping to switch over to Bell, as the Bell Fibe Internet has been alot better then my Rogers internet was, and the picture quailty on Rogers Cable is next to NIL now, there is way to many loose cable wires, illegal splitters on my building and what not, so I was hoping to be able to switch to Bell totally. -- I guess I stuck with looking for a HDTV Rabbit Ear setup now!
If anyone has any luck becoming a FibeTV customer in Toronto, I would love to here about it. -- I used up every number there is to call and become a customer.
1-866-269-8009 (the website number, but noone knows)
1-866-797-8686 (the old IPTV number, but you end with a story)
1-866-247-5703 (beats me, but sometimes they were helpful)
1-866-635-8375 (they claim to do the test to see if you are able)
1-866-230-2481 (seems to be internal, don't want to talk to you)
Good Luck People.
Story #1:
Story #2:
Story #3
THE END
Good Luck People.
