181 - 181 of 181 Posts
Hi. I have 2 9500 and one 7500 receiver and would info on hooking it all up. Anything extra I need? Their website says you can double the recording capabilities with 2 9500 receivers but how do you hook it up to gain that ability? Does it work like dish network setup
Yes it does exactly like dish network, two lines from DPP lnb go to Duo Hub, two lines that say host/advanced client go to 9500s, line in the middle saying client go to 7500. First connect two 9500, do a test on check switch screen, then wait until the software loaded. After that plug in 7500 and press 'download'. It will take few seconds to load and few minutes to install. Done! Just be sure not to plug in 7500 before 9500s are done. If you do, then 9500 will freeze, then you restart it and it will go to recovery mode, 50/50 chance it will recover or will become a brick.
