I need some assistance to troubleshoot an issue that I am having and have had no luck with both the 9200 manual and SC 25 manual to figure this out. I have the TV2 out coax cable going from the 9200 to my SC 25 coxial in which is in the basement. The SC 25 outputs video via HDMI to a ceiling mounted projector. I am not able to get any picture using this setup.
I pulled out the coaxial cable and plugged it in to an old TV just to make sure that the signal is coming through it and I tuned the old test TV to channel 74 and set up the 9200's modular setup screen to use channel 74 - and the signal shows up fine on the old TV.
I guess the issue is that there is no way (that I know if anyway) to "tune" the Pioneer SC 25 AV receiver to "channel 74" in order to sync up to the 9200 and receive the signal.
Can someone help me out here please? Is there a way to send my TV2 out signal on my Bell 9200 to an AVR as coax input and then output video via HDMI and audio using the AVR speaker outs? Hope that I described the scenario clearly enough.
