1 - 3 of 3 Posts
Do you need a Bell 9500 satellite receiver to run a Bell 7500 receiver or can you just have the one Bell 7500 satellite receiver hooked to your dish. Seems they are not selling the 6400 units anymore ?
So if you new customer then all you get is a 9500.
If you are existing customer and you have 9500 on the account then you can only get second 9500 or 7500. If you have only standard boxes or pre 9500 HD boxes then you get 6400, there is still stock, however remotes for them are mostly used (ie garbage). However if you order rental 9500 and tech shows up then they can install you whatever they have in a truck 6400-9400-9500 cause they can swap it in the app.
1 - 3 of 3 Posts
