1 - 3 of 3 Posts
Hi , is anyone monitoring their bandwidth their own way with some type of tool? I have a WRT54GL router with tomato firmware, and the bandwidth monitoring tool is usually pretty close to the Rogers website, usually just a bit over what Rogers tells me... so it helps so that i don't overshoot....
ODDLY enough, this month... my router says i've used over 60GB of bandwidth.
The Rogers tool : 36 GB. Those using a tool, have you noticed discrepancies too this month or is it just me? :confused::confused:
EDIT : a quick look at the daily usage on Roger's website tells me that i havent been using any bandwidth for 4 days at the middle of july...
huh?
I assume you weren't away or offline for the 4 days? I just checked my day-to-day usage and there's something every day for July, up to the 25th. I don't bother checking with another tool because I usually only use 1-2 GB/mo on Express.
1 - 3 of 3 Posts
