1 - 3 of 3 Posts
I am building a new home and getting it pre-wired. One of the quotes I will be getting uses Audiotrak speakers, has anybody heard anything or had any experience with Audiotrak speakers? Another quote is from someone who uses Paradigm speakers but has quoted me on a Breathe Audio Elevate Multi-Room receiver of which I haven't read many good reviews on. I already have a Yamaha HTR 6190 in storage, will this be sufficient. I will be planning on having a speaker(s) in the ensuite or the bedroom? I would think it would be better in the ensuite. Some patio speakers(2), living room(2), family room set up for surround sound( I have all Polk speakers including towers(RTi10's), center channel(CSi6), rear(?) and sub woofer(PSW?) from my old home. However the surrounds are a wall mount and I have an open style home with Family room, dining room and Kitchen and no place to put surrounds. So I'm think in ceiling. My 50" Pioneer will be wall mounted over a fireplace. I know the HT setup is a personal preference but any advice you would have for the Family room would be appreciated.
Discussion Starter · #2 ·
Nobody has heard of AudioTrak? No opinions either about my proposed setup. After thinking it through think I will be putting the surrounds on or in wall.
Premium Member
personally i think if your having a hard time finding anything useful re: these (audiotrak) speakers (good reviews, widely accepted, known ..etc) .. i would avoid them. paradigm would be good choice, in comparison i think (maybe the guy has other amp options)
lots of recognized speaker names that config. to in-wall, ceiling installation. seems you need to re-group and re-evaluate the choices offered to you, difficult for others to provide specfic feedback for this, if your looking for encouragement (or re-assurance for these brands) it's probably a significant investment too (understandably)
pre-wire the house for multi-zone while still roughed in (partitioned w/o drywall). don't rush into the hardware if your unsure . .. seems i am getting that vibe from you.
pre-wire (probably wireless methods for control, i would say) ...settle down and choose your arsenal at your leisure (speakers and MZ amps) ...afterward. even if you connect, configure yourself - which isn't a big deal. good learning experience ..and you'll feel better about your choices probably.
re: the 6190. you may need external amps, external infrared....yes i suppose you can use the 6190 as the controller, if you choose up to 3 zones using external amps. if you choose to use the internal maps of the AVR (mind you i haven't done this and doesn't appear pratical given what you want to accomplish - you will be better off with external amps it seems) exercise care when it comes to multiple pairs of speakers, meaning the loads on your 6190. different scenerios. for example, the manual warns against passive loudspeaker selector boxes. my understanding is that this provides a method to select (switch) to different paired speakers (different zones) .. it is my understanding some don't control impedence. i think this is what they mean in the manual... boxes may present lower impedence (or when trying to drive multiple speaker pairs)
anyways ... just some thought, opinion. check it out thoroughly, it's important. or simply get more (other) installer input. intended not to plug these guys (with the act of providing link) .. but may allow (trigger) other thought for you, motive to dig deeper, verify/compare pricing maybe ..etc. good luck.
http://www.aartech.ca/
1 - 3 of 3 Posts
