Hi,
I have just installed a Sony 32EX710 HDTV and obtained a Cogeco HD receiver last weekend.
I set up the cables between the HD Receiver and the HDTV, with the 3 Video and 2 Audio cables. Everything works okay, I get picture and sound.
With regards to Audio, I am able to adjust the Audio on the TV and on the HD Receiver... nice...
Subsequently, I decided I would replace the Video and Audio cables with an HDMI cable connection between the HD Receiver and the HDTV.
Problem... now I can only adjust the volume on the HDTV. The remote can turn the HD Receiver ON/OFF and Mute the HD Receiver, but the Audio cannot be adjusted... only on the HDTV.
Can anyone offer any help or insight with this issue?
Thanks very much.
Regards, Kevin.
Burlington, ON
Thanks very much.
Regards, Kevin.
Burlington, ON
