Area 51 for Antenna Modelers & Builders (See Post #1)
423522 Views 1327 Replies 63 Participants Last post by  majortom
This thread has been created strictly for Antenna Modelers and Builders who like to live not just on the leading edge but on the bleeding edge of antenna research and development.
Area 51 is for posting and discussion of any computer model of any experimental antenna by Antenna Modelers and Builders
Area 51 is not for casual builders or newcomers to ask questions or look for useable home antennas. Participants here are expected to fairly well "know their stuff".
If an antenna design is shown to be worthwhile for general public consumption we will move it out of Area 51 into the main Antenna Research & Development Forum.
Just remember what the ancient map makers wrote when they had no further info to illustrate: "Beyond here be dragons!"
221 - 240 of 1328 Posts
Here are the dimensions for the top hat that I'm going to use (I need Ch.7). Top 18.6",down 1", in (both sides) 2", down 0.8" out 4.5"(both sides). It will be 0.4" (10mm) above the stubs on the GH.
This is somewhat surprising. Using the Top Hat NAROD on the SBGH gen 1, 89mm feedpoint, No Reflectors example above, I compared using a Top Hat NAROD reflector versus a straight NAROD reflector (for channels 10 - 13) and got this:
Code:
Top Hat NAROD reflector 10 inch spacing
     Raw
Mhz Gain  SWR
195 7.95  2.19      Note: gain direction is flipped, 6.33dBi in the correct direction
201 9.04  2.26
207 9.98  2.78
213 9.00  2.35
Straight 28 inch NAROD reflector 10 inch spacing
     Raw
Mhz Gain  SWR
195  8.7   1.71     Note: The gain direction is not flipped.
201 10.1   2.32
207  9.9   2.75
213  9.3   2.77
I was really expecting the NAROD reflector with the same shape as the Top Hat NAROD to have the better gain. Either way, its a healthy increase with a NAROD reflector. The simple straight one looks to be a bit better and no change in the dip.
(the reason I chose the SBGH gen1 to example with is that unlike JEDs designs, the uhf reflectors arent above the stubs. That could complicate things later on. Also, my meaning of the correct direction on a reflectorless SBGH means the NAROD is in front of the NAROD reflector towards the transmitter, heh.)
See less See more
Running the NEC 2NEC4 complains about unequal segmentation of the parallel segments. Not sure if this is valid or a bug. To me the segments are equally segmented but maybe I am missing something? /Quote
To me the segments look equal too, after saving in Geometry Edit. It must be in the segmentation the SY cards do. I seem to recall someone else mentioning that on the 4nec2 forum.
RELEASE NOTES
Changes for 5.7.5 (9 Jul 2009)
- Bugfix in variable sweeper when having specified a freq-sweep in the Nec input-file.
- Bugfix in optimizer when using 'fast-ground'together with radial groundscreen.
- Bugfix for duplicate NT lines in 'new Nec editor' when only empty lines were entered.
- Problem fixed when starting Notepad/Wordpad programs on case-sensitieve Windows-95 systems.
- Bugfix when updating surface-patch continuation data (SC card) from withing new Nec-editor.
- Bugfix for accidentally introduced bug (to fix below TL-tag problem) in RLC-matching window (F10).
- Bugfix for percentual TL tag/segment number positioning.
- Few other minor fixes.
Maybe its fixed in the update ?
I Have to check it out, thanks for the tip.
Another junk U tube antenna Bad design
DO not build
CE u-tube
GW 1 3 0 -1.05 0 0 1.05 0 0.04
GW 2 9 0 -1.05 0 0 -1.05 6.5 0.04
GW 3 9 0 -1.05 6.5 0 -1.55 0 0.04
GW 4 6 0 -1.55 0 -0.1 -2.1 4.8 0.04
GW 5 6 0 -2.45 7.66 0 -7.35 7.66 0.04
GW 6 9 0 -7.35 7.66 0 -7.35 0 0.04
GW 7 7 0 -7.35 0 0 -2.25 0 0.04
GW 8 11 0 -2.25 0 0 -2 7.66 0.04
GW 9 5 0 -2 7.66 0 2 7.66 0.04
GW 10 11 0 2 7.66 0 2.25 0 0.04
GW 11 7 0 2.25 0 0 7.35 0 0.04
GW 12 11 0 7.35 0 0 7.35 7.66 0.04
GW 13 7 0 7.35 7.66 0 2.45 7.66 0.04
GW 14 11 0 2.45 7.66 -0.1 2.1 4.8 0.04
GW 15 9 0 1.55 0 0 1.05 6.5 0.04
GW 16 9 0 1.05 6.5 0 1.05 0 0.04
GW 17 3 -0.1 -2.1 4.8 0 -2.45 7.66 0.04
GW 18 3 -0.1 2.1 4.8 0 1.55 0 0.04
GS 0 0 0.0254
GE 0
EK
LD 5 0 0 0 5.8e7 0
EX 0 1 2 0 1 0
GN -1
FR 0 1 0 0 470 0
XQ
EN
Edit: It look very much like a "Joe Carr" Six Shooter.
See less See more
4nec2 refused to run due to segmentation problems....GW14 has way too many.
I made fol. changes so L and R sides match up:
GW17 from 3 to 5, GW14 from 11 to 5 and GW18 from 3 to 6.
Autosegmenter gives significantly different results, depending on chosen segment number,
so I didn't go that route...
Since the Azimuthal pattern is max towards 240-deg at 174 MHz, 4nec2's Gain curve
is for that direction. The Gain towards 90-deg can be seen in the Azimuthal plot by
hitting the "J" key and navigate freq & azimuth via arrow keys. To PLOT the Gain curve
towards 90-deg, enable the FP statement below for "1D Gain" and comment out the
"2D Azimuthal Gain Slice" statement (a single quote mark, as shown below).
Gain is 3.0 dBi (174 MHz), rising to 8.5 dBi (566 MHz) and falling to 3.7 dBi (698 MHz).
But the SWR starts at 6, has a very narrow dip to 1.06 at 566 MHz and quickly jumps
to 22, so it's excessive over most of the UHF band, which can cause problems in many
situations, depending on cable length and other factors.
So, like many U-Tube wonders, it has some Raw Gain but is inherently defective....
Modified 4nec2 file:
CM Yet another U-Tube Defect, 4nec2 by Xauto, 24July2009
CM Segmentation corrected by holl_ands
CE
GW 3 6 0 -1.05 6.5 0 -1.55 0 0.04
GW 14 5 0 2.45 7.66 -0.1 2.1 4.8 0.04
GW 17 5 -0.1 -2.1 4.8 0 -2.45 7.66 0.04
GS 0 0 0.0254
GE 0
EK
LD 5 0 0 0 5.8e7 0
EX 0 1 2 0 1 0
GN -1
' FR Freq Sweep choices in order of increasing calculation time:
' FR 0 29 0 0 470 12 ' Freq Sweep 470-806 every 12 MHz
FR 0 39 0 0 470 6 ' Freq Sweep 470-698 every 6 MHz - PREFERRED FOR UHF
' FR 0 77 0 0 470 3 ' Freq Sweep 470-698 every 3 MHz
' FR 0 153 0 0 470 1.5 ' Freq Sweep 470-698 every 1.5 MHz
' RP choices in order of increasing calculation time:
' RP 0 1 1 1510 90 0 1 1 0 0 ' 1D Gain toward 90-deg Azimuth
' RP 0 1 37 1510 90 0 1 5 0 0 ' 2D (Left only) Azimuthal Gain Slice
RP 0 1 73 1510 90 0 1 5 0 0 ' 2D Azimuthal Gain Slice - PREFERRED
' RP 0 73 1 1510 90 0 5 1 0 0 ' 2D Elevation Gain Slice
' RP 0 73 73 1510 90 0 5 5 0 0 ' 3D Lower Hemisphere reveals antenna
' RP 0 145 73 1510 90 0 5 5 0 0 ' 3D Full Coverage obscures antenna
EN
See less See more
holl_ands: Thank you for the help. I still have not mastered 4nec2. I can get it to almost work 1/2 the time.
Edit:5:40AM 25 July. I look at this antenna again. It is small is size (7.7"X14.7") and if your Ch.s are from 23to37, it will work for you. This is not my first choice to use 8 feet of wire. If I had 8' of #12 I would make X-32 and get all (14-51) of the UHF.
Like from here ? http://books.google.com/books?id=q1...-4zHBQ&sa=X&oi=book_result&ct=result&resnum=1
Ive had a lot of old juke box style short wave/am/fm radios that had that box loop antenna in them, heh.
Rounding the corners in the example in post #220, to make a little easier build using pipes as a form, like this:
Produces this:
Code:
Net
 Gain	Channel
-4.7648	7
-1.0122	8
2.3001	9
4.8475	10
6.1502	11
6.2877	12
5.8249	13
6.0302	14
6.4712	15
6.8727	16
7.2152	17
7.5200	18
7.7790	19
8.0047	20
8.1998	21
8.3670	22
8.4993	23
8.6193	24
8.7098	25
8.7834	26
8.8424	27
8.8895	28
8.9078	29
8.9111	30
8.8757	31
8.7921	32
8.6345	33
8.4667	34
8.4436	35
8.5792	36
8.7411	37
8.8772	38
8.9841	39
9.0821	40
9.1707	41
9.2699	42
9.3805	43
9.5035	44
9.6410	45
9.7948	46
9.9670	47
10.1491	48
10.3308	49
10.5083	50
10.6510	51
10.7181	52
The vhf-hi gain shifts slightly to the higher channels.
The NEC file:
CM SBGH gen1 89mm feedpoint with Top Hat NAROD rounded corners
CE
GW 5 15 0 0 17.325 0 7.0587 17.325 0.05094488
GW 6 5 0 5.5569 16.2636614 0 7.0587 16.2636614 0.05094488
GW 7 3 0 7.3087008 17.075 0 7.3087008 16.5137 0.05094488
GW 8 1 0 5.3069016 16.0137 0 5.3069016 15.7486 0.05094488
GW 9 11 0 5.5569 15.4986205 0 10.9661929 15.4986221 0.05094488
GW 15 15 0 0 -17.325 0 7.0587 -17.325 0.05094488
GW 16 5 0 5.5569 -16.263661 0 7.0587 -16.263661 0.05094488
GW 17 3 0 7.3087008 -17.075 0 7.3087008 -16.514 0.05094488
GW 18 1 0 5.3069016 -16.014 0 5.3069016 -15.749 0.05094488
GW 19 11 0 5.5569 -15.499 0 10.9661929 -15.498622 0.05094488
GW 25 15 0 0 17.325 0 -7.0587 17.325 0.05094488
GW 26 5 0 -5.5569 16.2636614 0 -7.0587 16.2636614 0.05094488
GW 27 3 0 -7.3087008 17.075 0 -7.3087008 16.5137 0.05094488
GW 28 1 0 -5.3069016 16.0137 0 -5.3069016 15.7486 0.05094488
GW 29 11 0 -5.5569 15.4986221 0 -10.966193 15.4986221 0.05094488
GW 35 15 0 0 -17.325 0 -7.0587 -17.325 0.05094488
GW 36 5 0 -5.5569 -16.263661 0 -7.0587 -16.263661 0.05094488
GW 37 3 0 -7.3087008 -17.075 0 -7.3087008 -16.514 0.05094488
GW 38 1 0 -5.3069016 -16.014 0 -5.3069016 -15.749 0.05094488
GW 39 11 0 -5.5569 -15.498622 0 -10.966193 -15.498622 0.05094488
GW 30 15 0 1.73228346 0 0 6.73228346 5 0.05094856
GW 31 15 0 1.73228346 10 0 6.73228346 5 0.05094856
GW 32 15 0 1.73228346 10 0 6.73228346 15 0.05094856
GW 34 15 0 -1.7322835 0 0 -6.7322835 5 0.05094856
GW 35 15 0 -1.7322835 10 0 -6.7322835 5 0.05094856
GW 36 15 0 -1.7322835 10 0 -6.7322835 15 0.05094856
GW 38 15 0 1.73228346 0 0 6.73228346 -5 0.05094856
GW 39 15 0 1.73228346 -10 0 6.73228346 -5 0.05094856
GW 40 15 0 1.73228346 -10 0 6.73228346 -15 0.05094856
GW 42 15 0 -1.7322835 0 0 -6.7322835 -5 0.05094856
GW 43 15 0 -1.7322835 -10 0 -6.7322835 -5 0.05094856
GW 44 15 0 -1.7322835 -10 0 -6.7322835 -15 0.05094856
GW 103 13 0 6.73228346 15 0 12.3228346 15 0.05094856
GW 104 13 0 -6.7322835 15 0 -12.322835 15 0.05094856
GW 106 13 0 6.73228346 -15 0 12.3228346 -15 0.05094856
GW 107 13 0 -6.7322835 -15 0 -12.322835 -15 0.05094856
GW 146 3 0 -1.7322835 0 0 1.73228346 0 0.011
GW 147 1 0 -7.0587 17.325 0 -7.3087008 17.075 0.05094856
GW 148 1 0 -7.3087008 16.5137 0 -7.0587 16.2636614 0.05094856
GW 149 1 0 7.0587 17.325 0 7.3087008 17.075 0.05094856
GW 150 1 0 7.0587 16.2636614 0 7.3087008 16.5137 0.05094856
GW 151 1 0 -7.0587 -16.263661 0 -7.3087008 -16.514 0.05094856
GW 152 1 0 -7.3087008 -17.075 0 -7.0587 -17.325 0.05094856
GW 153 1 0 7.0587 -16.263661 0 7.3087008 -16.514 0.05094856
GW 154 1 0 7.3087008 -17.075 0 7.0587 -17.325 0.05094856
GW 155 1 0 -5.5569 16.2636614 0 -5.3069016 16.0137 0.05094856
GW 156 1 0 -5.3069016 15.7486 0 -5.5569 15.4986221 0.05094856
GW 157 1 0 5.5569 16.2636614 0 5.3069016 16.0137 0.05094856
GW 158 1 0 5.3069016 15.7486 0 5.5569 15.4986205 0.05094856
GW 159 1 0 -5.5569 -15.498622 0 -5.3069016 -15.749 0.05094856
GW 160 1 0 -5.5569 -16.263661 0 -5.3069016 -16.014 0.05094856
GW 161 1 0 5.5569 -15.499 0 5.3069016 -15.749 0.05094856
GW 162 1 0 5.3069016 -16.014 0 5.5569 -16.263661 0.05094856
GS 0 0 0.0254 ' All in in.
GE 0
EK
LD 5 0 0 0 5.8e7 0
EX 0 146 2 0 1 0
GN -1
FR 0 39 0 0 473 6
RP 0 1 73 1510 90. 0. 0. 20. 0. 0.
EN
See less See more
I'm kind of surprised the GX card hasn't caught on more. Model files are so much easier to digest when you only have to deal with the upper quadrant.
For example, using a GX card a reflectorless SBGH can be brought down to just 5 GW cards (4 zigzags, plus the exicited element).
Code:
GW 10 15 0 1.73228346 0 0 6.73228346 5 0.05094856
GW 11 15 0 1.73228346 10 0 6.73228346 5 0.05094856
GW 12 15 0 1.73228346 10 0 6.73228346 15 0.05094856
GW 13 13 0 6.73228346 15 0 12.3228346 15 0.05094856
GX 100 011
GW 901 3 0 -1.7322835 0 0 1.73228346 0 0.011
A SBGH with reflectors can be brought down to 8.
Code:
GW 50 25 -4.1338583 0.39370079 2.5 -4.1338583 12.0078740 2.5 0.1875
GW 51 25 -4.1338583 0.39370079 7.5 -4.1338583 12.4409449 7.5 0.1875
GW 52 25 -4.1338583 0.39370079 15 -4.1338583 12.4409449 15 0.1875
GX 100 011
See less See more
Yet another U-Tube Defect: One more correction.
AutoGainTest was way off. Reducing number of segments in GW1 helped, as well as a smaller radius:
GW 1 1 0 -1.05 0 0 1.05 0 0.007
Fewer segments in GW1 means the EX card also has to be changed:
EX 0 1 1 0 1 0
Results and 4nec2 file were posted here:
http://www.avsforum.com/avs-vb/showthread.php?p=16888175
holl_ands: Thanks for Not for TV. On that U-tube model, the slide show had no dimensions just a nail pattern and 8' of wire. So I eye-balled it. I was surprised that it ended up in the UHF band.
Heh, the Not Ready For Prime Time TV Antennas.
x-234
ok i wanted a nice 9 dbi for the VHF-HI with the SWR below 3 which i managed to do.
In the UHF the dbi is not that high 3 db more but i like the SWR for the 470 to 700 .
and yes i'm using 300ohms NARODs love them suckers
Need some help to bring up the dbi in the UHF 470 to 700 with out messing with my VHF -HI
Code:
CM Oringnal SBGH  design by John E. Davis
CM (wire Diam =7mm for array )
CM GHVHF-HI edit by WW
CE
GW	1	3	0	-2	0	0	1.2047244	0	0.11889764
GW	2	7	0	1.2047244	0	0	6.71653542	5.51181102	0.13779528
GW	3	7	0	6.71653542	5.51181102	0	1.2047244	11.023622	0.13779528
GW	4	7	0	1.2047244	11.023622	0	6.71653542	16.5354331	0.13779528
GW	5	5	0	6.71653542	16.5354331	0	10.9291339	16.5354331	0.13779528
GW	6	7	0	1.2047244	0	0	6.71653542	-5.511811	0.13779528
GW	7	7	0	6.71653542	-5.511811	0	1.2047244	-11.023622	0.13779528
GW	8	7	0	1.2047244	-11.023622	0	6.71653542	-16.535433	0.13779528
GW	9	5	0	6.71653542	-16.535433	0	10.9291339	-16.535433	0.13779528
GW	10	7	0	-2	0	0	-7.511811	5.51181102	0.13779528
GW	11	7	0	-7.511811	5.51181102	0	-2	11.023622	0.13779528
GW	12	7	0	-2	11.023622	0	-7.4952756	16.6	0.13779528
GW	13	5	0	-7.4952756	16.6	0	-11.795276	16.6	0.13779528
GW	14	7	0	-2	0	0	-7.511811	-5.511811	0.13779528
GW	15	7	0	-7.511811	-5.511811	0	-2	-11.023622	0.13779528
GW	16	7	0	-2	-11.023622	0	-7.511811	-16.535433	0.13779528
GW	17	5	0	-7.511811	-16.535433	0	-11.72441	-16.535433	0.13779528
GW	18	27	0	-15.5	17	0	15	17	0.16243037
GW	19	27	0	-17.5	-17	0	13	-17	0.16243037
GW	20	29	0	-16	37	0	16	37	0.16243037
GW	21	29	0	-17	-37	0	15	-37	0.16243037
GW	22	11	-4	-5.7952756	-1	-4	5.2047244	-1	0.16243037
GW	23	11	-4	-5.7952756	1	-4	5.2047244	1	0.16243037
GW	24	13	-4	-6.7952756	7	-4	6.2047244	7	0.16243037
GW	25	13	-4	-6.7952756	-7	-4	6.2047244	-7	0.16243037
GW	26	15	-4	-8.7952756	13	-4	7.2047244	13	0.16243037
GW	27	15	-4	-8.7952756	-13	-4	7.2047244	-13	0.16243037
GW	28	29	-16	-16	17	-16	16	17	0.16243037
GW	29	29	-16	-18	-17	-16	14	-17	0.16243037
GW	30	41	-16	-23	8	-16	23	8	0.16243037
GW	31	41	-16	-23	-8	-16	23	-8	0.16243037
GE	0
EK
LD	5	0	0	0	2.49e7	0
EX	0	1	2	0	1	0
GN	-1
FR	0	1	0	0	210	0
See less See more
wildwillie: Do you have two NAROD at each end (one @ 17" and one @ 37" [ this one out of the box])? Looks like a net gain of 8dBi on VHF-hi.
Xauto yes i have 4 NARODs
2 as you can see are 37 inches off from X Z+37 and Z-37
with 4 reflectors for VHF_HI back around 16 inches
I was going to test out putting 2 directors also
But i have a gut feeling that the UHF SWR will rise
X-234 V2 added 4 directors For VHF_HI
and i brought the UHF reflectors in 1 inch
Code:
CM GHVHF-HI edit by WW V2
CE
GW	22	11	-3	-5.7952756	-1	-3	5.2047244	-1	0.16243037
GW	23	11	-3	-5.7952756	1	-3	5.2047244	1	0.16243037
GW	24	13	-3	-6.7952756	7	-3	6.2047244	7	0.16243037
GW	25	13	-3	-6.7952756	-7	-3	6.2047244	-7	0.16243037
GW	26	15	-3	-8.7952756	13	-3	7.2047244	13	0.16243037
GW	27	15	-3	-8.7952756	-13	-3	7.2047244	-13	0.16243037
GW	32	21	4	-11	17	4	11	17	0.16243037
GW	33	21	4	-12	-17	4	10	-17	0.16243037
GW	34	17	8	-10	17	8	9	17	0.16243037
GW	35	17	8	-10	-17	8	9	-17	0.16243037
GE	0
EK
LD	5	0	0	0	2.49e7	0
EX	0	1	2	0	1	0
GN	-1
FR	0	1	0	0	210	0
See less See more
X-234 V3
UHF band 11 dbi
VHF_HI 7 to 13 8dbi and above SWR below 3
Xauto I brought everything back in to the box hehe
Code:
CM GHVHF-HI V3 edit by WW SWR for all bands covered below 3
CE
GW	4	7	0	1.2047244	11.023622	0	6.87432708	16.6957545	0.13779528
GW	5	5	0	6.87432708	16.6957545	0	12.0336681	16.6957545	0.13779528
GW	9	5	0	6.71653542	-16.535433	0	11.8756205	-16.481135	0.13779528
GW	13	5	0	-7.4952756	16.6	0	-12.654626	16.6	0.13779528
GW	17	5	0	-7.511811	-16.535433	0	-12.671161	-16.535433	0.13779528
GW	20	29	0	-18	24.3587167	0	15	24.3587167	0.16243037
GW	21	29	0	-18	-24.519037	0	15	-24.519037	0.16243037
GW	28	29	-13.948718	-16	17	-13.948718	16	17	0.16243037
GW	29	29	-13.948718	-18	-17	-13.948718	14	-17	0.16243037
GW	30	41	-13.948718	-23	8	-13.948718	23	8	0.16243037
GW	31	41	-13.948718	-23	-8	-13.948718	23	-8	0.16243037
GW	32	7	0	-4	21.3587167	0	3	21.3587167	0.16243037
GW	33	7	0	-4	-21.519037	0	3	-21.519037	0.16243037
GW	34	9	0	-6	22.3587167	0	4	22.3587167	0.16243037
GW	35	9	0	-6	-22.519037	0	4	-22.519037	0.16243037
GW	36	15	0	-9	23.3587167	0	8	23.3587167	0.16243037
GW	37	15	0	-9	-23.519037	0	8	-23.519037	0.16243037
GE	0
EK
LD	5	0	0	0	2.49e7	0
EX	0	1	2	0	1	0
GN	-1
FR	0	1	0	0	210	0
See less See more
I ran the above file using 4nec2 and found:
UHF Gain = 11.6 dBi (+/- 0.75 dB) for Ch14-51.
Hi-VHF Gain = 8.6 dBi (+/-0.4 dB) for Ch7-13.
SWR<3.0 for either UHF or Hi-VHF
Finally, a DBGH with excellent performance in both UHF and Hi-VHF Bands!!!!
However, in order for AutoGainTest=1.0 on Hi-VHF the SOURCE wire Radius must be changed:
UHF: 0.12 (or 0.11889764 if you like overkill....)
Hi-VHF: 0.08
Notes re unequal segmentation on parallel wires might not be important,
but I did notice that 4nec2's AutoSegmenter could not get them go away.
FWIW, if you calculate the segment length for GW1 and compare to segment
length for other wires (esp. longer wires), more "equal" segmentation results
taking each wire length (use Geometry Editor) and divide by the segment length for GW1.
No, I didn't take the time to crank out the numbers for the entire file...
See less See more
x-240
have a look gain is not to bad for VHF_HI
this is a copy of 300ohms DBGH no reflector 88mm feedgap
Code:
CM 300ohms DBGH no reflector
CM 88mm feedgap
CM 10 gauge phasing line with 2 inch phasing line gap, 1 inch high
CM VHF_HI edit by WW channel 7 needs to have SWR worked on
CE
GW	30	7	0	1.73228346	-17.635271	0	6.73228346	-12.635271	0.06424494
GW	31	7	0	1.73228346	-7.6352715	0	6.73228346	-12.635271	0.06424494
GW	32	7	0	1.73228346	-7.6352715	0	6.73228346	-2.6352715	0.06424494
GW	34	7	0	-1.7322835	-17.635271	0	-6.7322835	-12.635271	0.06424494
GW	35	7	0	-1.7322835	-7.6352715	0	-6.7322835	-12.635271	0.06424494
GW	36	7	0	-1.7322835	-7.6352715	0	-6.7322835	-2.6352715	0.06424494
GW	38	7	0	1.73228346	-17.635271	0	6.73228346	-22.635271	0.06424494
GW	39	7	0	1.73228346	-27.635271	0	6.73228346	-22.635271	0.06424494
GW	40	7	0	1.73228346	-27.635271	0	6.73228346	-32.635271	0.06424494
GW	42	7	0	-1.7322835	-17.635271	0	-6.7322835	-22.635271	0.06424494
GW	43	7	0	-1.7322835	-27.635271	0	-6.7322835	-22.635271	0.06424494
GW	44	7	0	-1.7322835	-27.635271	0	-6.7322835	-32.635271	0.06424494
GW	46	7	0	6.73228346	2.36472854	0	13.742954	2.36472854	0.06424494
GW	47	7	0	-6.7322835	2.36472854	0	-13.742953	2.36472854	0.06424494
GW	55	7	0	-6.7322835	2.36472854	0	-1.7322835	7.36472854	0.06424494
GW	56	7	0	6.73228346	2.36472854	0	1.73228346	7.36472854	0.06424494
GW	57	7	0	-6.7322835	32.3647285	0	-1.7322835	27.3647285	0.06424494
GW	58	7	0	6.73228346	32.3647285	0	1.73228346	27.3647285	0.06424494
GW	61	7	0	-1.7322835	7.36472854	0	-6.7322835	12.3647285	0.06424494
GW	62	7	0	1.73228346	7.36472854	0	6.73228346	12.3647285	0.06424494
GW	66	7	0	1.73228346	17.3647285	0	6.73228346	22.3647285	0.06424494
GW	67	7	0	-6.7322835	22.3647285	0	-1.7322835	27.3647285	0.06424494
GW	68	7	0	6.73228346	22.3647285	0	1.73228346	27.3647285	0.06424494
GW	69	7	0	1.73228346	17.3647285	0	6.73228346	12.3647285	0.06424494
GW	100	7	0	6.73228346	32.3647285	0	13.7429516	32.3647285	0.06424494
GW	101	7	0	-6.7322835	32.3647285	0	-13.742953	32.3647285	0.06424494
GW	103	7	0	6.73228346	-2.6352715	0	13.7429516	-2.6352715	0.06424494
GW	104	7	0	-6.7322835	-2.6352715	0	-13.742953	-2.4749508	0.06424494
GW	106	7	0	6.73228346	-32.635271	0	13.7429516	-32.635271	0.06424494
GW	107	7	0	-6.7322835	-32.635271	0	-13.742952	-32.474951	0.06424494
GW	121	1	0	-1.7322835	-17.635271	1	-1	-17.635271	0.0511811
GW	127	7	0	-6.7322835	22.3647285	0	-1.7322835	17.3647285	0.06424494
GW	128	7	0	-6.7322835	12.3647285	0	-1.7322835	17.3647285	0.06424494
GW	129	1	0	-1.7322835	17.3647285	1	-1	17.3647285	0.0511811
GW	110	1	0	1.73228346	-17.635271	1	1	-17.635271	0.0511811
GW	130	17	1	-1	17.3647285	1	-1	-0.1352715	0.0511811
GW	131	1	0	1.73228346	17.3647285	1	1	17.3647285	0.0511811
GW	132	17	1	1	17.3647285	1	1	-0.1352715	0.0511811
GW	133	17	1	-1	-0.1352715	1	-1	-17.635271	0.0511811
GW	134	17	1	1	-0.1352715	1	1	-17.635271	0.0511811
GW	135	3	1	-1	-0.1352715	1	1	-0.1352715	0.077
GW	136	27	0	-15.069034	33.0796592	0	15.4309661	33.0796592	0.077
GW	137	27	0	-15.47219	-33.408719	0	15.0278102	-33.408719	0.077
GW	138	27	0	-15.314397	1.51192224	0	15.1856033	1.51192224	0.077
GW	139	27	0	-15.156607	-1.9580168	0	15.3433929	-1.9580168	0.077
GW	140	31	0	-15	50	0	18.9989402	49.7315491	0.077
GW	141	31	0	-17.5	-50	0	16.5	-50	0.077
GW	142	27	0	-14.367652	-0.2014044	0	14.5297827	-0.2014044	0.077
GW	143	11	0	-5.6015776	12.4823646	0	5.44378719	12.4823646	0.077
GW	144	11	0	-5.4437866	-12.687976	0	5.60157825	-12.687976	0.077
GW	145	11	0	-5.4437866	22.5825644	0	5.44378719	22.5825644	0.077
GW	146	11	0	-5.6015776	-22.788176	0	5.60157825	-22.788176	0.077
GW	147	11	0	-5.6015776	32.2018036	0	5.60157825	32.2018036	0.077
GW	148	9	0	-5.2859955	-32.567735	0	4.97041463	-32.567735	0.16243037
GW	149	29	-9.94971	-15.70513	33.091182	-9.94971	16.794875	33.091182	0.1624304
GW	150	29	-9.94971	-16.34615	-33.81764	-9.94971	16.153847	-33.81764	0.1624304
GW	151	29	-10	-15.70513	29.5	-10	16.7948748	29.5	0.1624304
GW	152	29	-10.14497	-16.34615	-38.20742	-10.14497	16.153847	-38.20742	0.1624304
GW	153	29	-10.14497	-15.70513	35.939882	-10.14497	16.794875	35.939882	0.1624304
GW	154	29	-10	-16.34615	-30.170345	-10	16.1538469	-30.170345	0.1624304
GW	155	37	-10.14497	-20	0	-10.14497	20	0	0.1624304
GE	0
EK
EX	0	135	2	0	1	0
GN	-1
FR	0	1	0	0	210	0
RP 0 1 10 1510 90. 0. 0. 20. 0. 0.
See less See more
