Hi All,
First post here, but I'm reading the forums since several months.
I'm looking to get an Apple TV (either the original one or G2), but I would like to ask some questions first:
Your feedback is highly appreciated!
Thank you!
- Is it possible to use Apple TV with DNS-323, i.e. if I have 3 iTunes libraries on the DNS (I'll be moving them there shortly), will I be able to use all of them (one at a time) with the Apple TV?
- Regardless of whether I will be able to use the DNS for iTunes, is there a way to "tell" the Apple TV to play specific playlist? My idea is to create several buttons on my Harmony One remote to play different playlists;
- Is it possible to play DVDs through the Apple TV using a PC in the local network? Yes, I have a DVD player, but I have PAL DVDs, which don't show up on my NTSC-only TV
. Yes, I can convert them to Apple TV-supported format or to NTSC (all these are family DVDs), but I would rather play them only on the PC;
- I purchased several movies from iTunes and they are all in my library. Is it possible to play them using Apple TV?
Thank you!
