1 - 4 of 4 Posts
With ATV, the manual says if you hold the play button for more than 3 seconds, the unit will automatically go into standby mode
This has worked maybe once for me, the rest of the time it doesn't
Anybody else having this problem?
Thanks in advance
Banned
yeah mine doesn't go into standby with the select/play button. i've got my harmony setup so 1 button turns on tv, receiver, and appletv. i'd say 75% of the time this works fine, but the other 25% of the time the appletv doesn't turn on (or off). the worst part is since the power button is the same as select play, i've started movies that i didn't want to watch just by turning my system on and off. i had to watch ironman wednesday night despite having to study for a test the next day. wasn't happy about that. thats what happens when apple tries to "cram" as few buttons as it can on a remote.
The new ATV firmware added a few functions to the pause command, so you have to be in the main menu (home) on ATV before shutting down by holding down pause. I guess a Harmony macro like <menu><menu><menu><pause5> might work.
Sorry,
No problems here. Works every time for me (Apple remote or Harmony 880), but I only do it from the main menu.
1 - 4 of 4 Posts
