1 - 1 of 1 Posts
Sadly, I took the advise of the Shaw tech that was out to service my external drive on my PVR (which was toast). When I said I had to run the utility to delete the programs that were recorded on the external drive from the PVR list, he told me he had a "faster way to do it". Just push Rewind, List, List, List, Live, and its done. Apparently, that command deletes the entire PVR recording index. The utility I wanted to run eliminates the index entries that are on a disconnected drive and comes up automatically after you try to play something on a disconnected drive. Stupid, stupid, stupid!
Anyone have any ideas on a rebuild index command? The drive still shows the proper amount of sapce used form the D13 diagnostics screen and the future recordings "should" default to going to the external drive now.
1 - 1 of 1 Posts
