21 - 40 of 48 Posts
How have you Pi owners been enjoying it? Done anything cool?
I just got one the other day, intending to turn it into an XBMC media player to stream content from my NAS, as well as using some of XBMC's interesting add-ons.
Discussion Starter #22
I played with XBMC on it as well. Almost tried the other day to get Chromium on it. I Really can't wait to try it as a Minecraft client. That should be fun! Sadly its been sitting collecting dust mostly. :(
I have mine up and running with XBMC now (RaspBMC). Very impressed. Works great as a media extender, streaming 1080p movies from the NAS. Hardly a hiccup. Coupled with an iPhone remote control app, it's great. Even can control it via my TV remote via HDMI-CEC. Also installed some of the goodies like 1Channel and IceFilms on it. Very pleased so far!
MinecraftPi released!
Installed Raspbain "wheezy" on a new 8GB Sandisk high speed card from Superstore ($19.00) and loaded up Minecraft! :) It's a port of the Android version with much less features such as no survival mode, but it ran really smooth.
PIs may be available locally from Sayal and Active Electronics. I bought one a few months ago from Active for $50, and I seen them for sale at Sayal for a bit more. I bought one of those inexpensive plastic cases which makes it much easier to handle.
Received a Raspberry Pi as a Christmas gift and just recently started to fiddle with it. Purchased a small TV (1080P, 22", $150) with HDMI to serve as monitor.
This worked straight away with the supplied OS. All set if I wanted to write PEARL and "C". Didn't.
The main app I found, a media center, was an implementation of XBMC for the Pi called "Raspbmc". It was one of three on offer, reviews of it, "OpenELEC" and "Xbian" indicated the latter were more particular. May try them later.
In any case, downloaded Raspbmc and put it on a fast SD card, put the SD in the Pi, connected and powered up. After some waiting and burps the assembly came to life and I now have a XBMC media centre which performs quite well. Plays videos from my laptop hard drive at 1080P over the LAN flawlessly and steams material from the internet (YouTube etc.) though that is slow in the condo.
Remote control is an app on the iPhone/iPad. Cool.
Using SSH from a laptop to log into the RPi running 1080p shows CPU utilization about 60-80% so there is a little headroom. 720p runs ~ 30%.
Works with AirPlay as well !
Have not previously used XBMC so having fun exploring that now.
I have been trying to use it as a desktop OS with "wheezy" loaded. It is painfully slow and I don't really like Midori much as a browser. It was much better at a Media Center with Raspbmc purpose built. Too bad there isn't Chrome ported to it.
Raspberry Pi
I have had mine for 6 months or so and just ordered a couple more.
I have used the first one to run XMBC - more on that in a minute.
Plan to use the next two for another XMBC box and the other one as a file server.
Have tried both the XMBC releases, i.e. Raspbmc & Openelec. Both work pretty well with a few common frustrations.
1) Biggest problem is getting Wi-Fi to work. I have half a dozen Wi-Fi dongles ranging from really old to pretty new. None of them have worked. Even when I go look at the recommended dongles, you still see people saying they can't get them to work. You can not drop to a terminal window so you have to use SSH to debug. BUT you can not have both a wired network and a Wi-Fi network at the same time. Makes it almost impossible to trouble shoot the Wi-Fi connection.
2) Remapping the TV remote would be pretty easy IF there was a way to capture the remote transmitted key ID. They tell you to use debug and look for the keys, but that is an exercise in frustration since the debug captures everything and you have to sort through a long list of commands looking for a specific key entry. Worse, the log seems to be written to file with a long delay. So you can't just press a key and then go read the log.
3) Using the Analog audio out has a number a issues - the worst is clicking/popping when the audio is stopped/started. For example between tracks, when jumping forward or back during video playback, etc. There are a few work arounds but I have not been able to make any of them work. (And I am a pretty experienced geek). There is also seems to be a lot of noise on the output. These appear to be hardware related issues not related to XMBC. The HDMI sound works great, but I hate to leave the TV on when listening to music.
4) I have a 40,000 file music library, Raspberry/XMBC apparently can't handle that size. Simply crashes. I am hoping the 512M version solves this problem.
5) The Web interface seems to crash freeze / not work quite a bit.
Sounds pretty negative, but all in all I like it enough to have ordered two more!
The Raspberry Pi was designed as an educational computer, not a fully functional PC. Getting it to run XBMC, or any other high level application, well is quite an achievement. I've got an old 1.2GHz P3 mATX motherboard that I play around with for stuff like this. It sounds like the RP is actually better and at a tiny fraction of the size.
I have one and I love it.
I use it with the OpenELEC operating system to give me an XBMC media centre setup. I use it exclusively for this purpose. I purchased a $3 IR receiver off eBay and use a remote control with it, although if you use your Pi with an HDMI display you can use a CEC remote with no extra configuration.
You can also use the default Raspbian OS and use it as a Debian system. I was thinking about getting another and using it as a file server.
Great little unit! And it can be overclocked to up to 1 GHz without frying it.
Discussion Starter #32
The Soc in the Pi actually has hardware acceleration for video so that it is why it is better at displaying video than an Atom based PC that may be much faster.
I have three of them and have been playing around with RaspBMC, I want to try using one as a PBX and the other as a temperature logger/sensor in my wine cabinet.
I have one since the beginning of 2013 and playin around with Openelec, Raspbmc and Xbian media center video playback from my NAS is pretty good actually, interesting device.
I have had mine for 6 months or so and just ordered a couple more....
I am pleased to report that the last time I booted Raspbmc it auto updated to release 12.1 (about 10 minutes) which fixed the Analog audio clicking/popping ! Very smooth now :) FLAC audio sounds superb.
As well YouTube and TED at 720p are flawless and CPU seems to be running at 25-30%(this may be the fast internet I have this week).
The user interface seems smoother but you can still outrun it.
If you go on the net with it, can it play netflix programming?
Discussion Starter #36
Not easily since you can't really get Netflix on any Linux distro without someone like Wine due to DRM issues (all of the OSes for the Pi are Linux variants). But you can get around this for SD content if you use Playon. And there is supposed to be an Android OS under development for the Pi that should work, if this Android version is ever released.
Ok, so last night I got to jonesing for some old time arcade action
then it dawned on me:
you could probably build a really awesome MAME machine out of a pi
I've found a couple of arcade machine plans, but I have one question about the pi
does it (or can you make it) behave kinda like a PC in that when it powers down, it shuts a monitor down as well?
ie, when it stops sending video signal, the monitor will go into power save mode
EDIT: and 5 seconds extra of googling finds a million projects like this already, including some kickstarter lol
There is no power button so the video signal stays on after you shutdown the OS down until you physically unplug the power of the Pi. Once you do that, I believe the monitor goes into standby.
Depending, on your perspective, that is good or bad.
For me, it would be good, in that it would give me a hardware project to make a power controller.
21 - 40 of 48 Posts
