1 - 3 of 3 Posts
My 630 allows me to browse selections and select a show then it sits there and does nothing. Network check OK; OK but not good: about 3.5Mbps down which should be good enough for SD but not HD.
This started yesterday.
Full disclosure: I have been having erratic speeds on my DSL. It should be 5+ but it's a lot less. Called Bell and the tech came out yesterday and made some changes but this no VoD started before he got here.
So, anybody else?
Discussion Starter #2
OK: here's another datapoint. I loaded Free Range on my PC and VoD works on it.
I'm going to pull the plug on my 630 then restart to see if that makes a difference.
Discussion Starter #3
Well, I should have tried pulling the plug before posting here: it's working after hard reset.
Sorry for the bother.
1 - 3 of 3 Posts
