1 - 3 of 3 Posts
I am feeding the 9241 via HDMI into my Home Theatre amp then out to my Plasma. My computer monitor is also an HDTV (LCD) which uses a component cable hook up. If I hook the HDMI and component cable to the 9241 will the output go through both cables - or maybe one or the other I can change in the setup menu? The reason I am asking is sometimes I may not need to crank up the big TV and using the monitor as my TV may be good enough if I just want to check a score or whatever out. Maybe some kind of splitter or hub deal is available? The 9242 probably would have been easier to accomplish this but I can't find any new ones anywhere. Thanks
1 - 3 of 3 Posts
