101 - 113 of 113 Posts
One thing I have found is that I may get a slow MTS test result until I reboot my PC and then it brings the speed back to normal on the tests.
Not sure if the PC / Router / MTS tv gateway is the problem but when a new session starts it back to normal.
Mozza, does it really matter who has the slowest speed test? If I am paying for 25 and not getting it then I am getting ripped off? Is this that hard to follow?
So did a re test, results as follows:
Speedtest.net - 17.95
Shaw - 25.1
testmynet - 10.6
Cogeco - 20.54
Primus-12.44
Bell- 26.65
So 2 tests show I am getting my money's worth, 4 don't. So I'll say again, I could be getting ripped off and have absolutely no way to prove it. And if I believe MTS own test then I am getting less than 1/2 the speed I am paying for.
It seems to me that when you do different speed tests, the one constant factor is your local connection to MTS. The variation has to come from the far end. Therefore, the fastest result has to be true for your home to the MTS server.
I'm prepared to accept arguments for/against.
Dave S.
Not necessarily the "best" speed test out there but I was downloading a large file this weekend and my Lighting 25 was reporting a steady number suggesting the connection was actually at 30 Mbps and even tipped into the 31 range at times. As advertised it would not exceed 25. I have seen this behaviour in the past too before official speed bumps were announced. MTS also has a history of giving higher than posted Internet speeds to customers that have TV and Internet which I do.
I'm wondering if "history" is the appropriate word here, or is it just a rumour?
I don't know how someone would verify that customers in the same location with varying numbers of services would get different speeds.
Dave S.
Just received an odd call from "Midwest Telecom Services" offering me a free upgrade for 3 months to Lightning 25. They seemed to know information about MTS, but the woman certainly sounded a bit "sketchy"... decided not to jump on it and to call MTS directly to find out. Anyone else?
I got the same call last month and signed up. My speed increased a few days later and my bill shows Lightning 25 with a corresponding bill credit.
Would it be midwest teleservices international? I just did a search, and they are located in Brandon. I would be apprehensive too, but as far as I know, all the MTS Connect stores are owned by third parties. So I would assume this is the same case with phone sales.
For the past few years MTS has been using a private call center out of Brandon to do tele- marketing for them.
They usually call me with special deals to upgrade to the Ultimate TV from Classic TV. Also had one call from them when my cell plan expired asking if I wanted to change handsets?
