1 - 2 of 2 Posts
I'm looking into building a HTPC but I'm just starting to gather info so please be patient with me !
Is there ANY graphic card that will support the latest HDMI 1.3a video features such as 120 hz, 24p, Deep Color, etc AND the latest HD Audio WITHOUT downsampling (Dolby TrueHD & DTS-HD Master Audio @ 16/24-bit / up to 96.0khz).
From my research, the answer is NO; true ? Any cards coming soon supporting this ?
The info I did find though is that there is one sound card supporting the sound part: the ASUS Xonar HDAV1.3 (the Auzentech Auzen X-Fi HomeTheater 7.1 will be out soon also).
If this is true, does that mean that you need to take a HDMI cable from the output of the graphic card and plug it in the HDMI input of the sound card, then take the HDMI output of the sound card and plug it in your AVR ? Can it be done by the interns ?
If this is the setup required for full HD support without compression, what graphic card do you suggest to support all the video HD features ?
Thanks !
1 - 2 of 2 Posts
