1 - 9 of 9 Posts
Hi,
I am looking to install a couple of FTA dishes.
Are there any good documents that i can use for help me set up a system?
Read ya l8r,
Al
Search the web for "Glorystar install guide". While that applies specifically to their system, the principles apply to Ku FTA in general.
You will need your specific receiver user manual to see where to plug numbers in, if it is not intuitive.
You can get angles at dishpointer.com , frequencies at Lyngsat.com
I either write down what I need from those sites, or take my computer out with me to the dish (possible with netbook and WiFi).
You could look at DrSat's site. He has a pretty good section on installation and other FTA info.
Indeed he does, some very good info on his site.
Discussion Starter · #8 ·
There are some videos on youtube about FTA. But often the videos dont have everything. Whereas Docs will point even the most smallest detail.
(Like Grounding. What are the correct setting to get the right TP numbers in your receiver. Or how do I invert the Dish so i can aim it at <10 degrees)
read ya l8r,
Al
1 - 9 of 9 Posts
