Does this antenna belong to the wacky tacky thread or will it be a good substitute for the Eagle Aspen rotator.
"FiveStar Outdoor HD TV Antenna Strongest Up to 200 Miles Long Range with Motorized 360 Degree Rotation, UHF/VHF/FM Radio Infrared Remote Control with Installation Kit and Jpole"
I wired my house when it was being built for a second antenna, running only a single RG6 cable though the ceiling and down an inside wall (Slab construction, no crawl space). I was thinking I could use the same cable for the antenna and rotator with the Eagle Aspen model, but it's no longer available. With my other antenna is on a CM ratator and I have to tweak the direction once in a while to get the fringe stations
Laurie in Ladner BC with 2 roof mounted DB8e's with one on the CM rotator.
