Nearly all of the US Networks (ABC, CBS, NBC, FOX, CW) are on Channel assignments that are
ADJACENT or
NEXT Adjacent (aka
"TABOO") to strong, nearby Canadian Stations. Although there are no MANDATORY DTV Tuner Specs, the Low-Rez CECB (U.S. Coupon Eligible Converter Boxes) were REQUIRED to meet the ADJACENT (Table 2) and TABOO (Table 3) Requirements found in the fol. document, which were derived from ATSC A/74 Receiver Implementation "Guidelines":
http://www.ntia.doc.gov/legacy/dtvcoupon/DTVmanufacturers.pdf
Hence, Tuners manufactured after 2007 "should" tolerate Adjacent Channel Interference that is about 33 dB STRONGER than the Desired Signal and 44+ dB for Next Adjacent (aka Taboo) Channels. HOWEVER, we should also bear in mind that these were BENCH Tests with NON-FADING signals, so in practice we should
try to keep Adjacent Interference no higher than about 20 dB Stronger than the Desired (probably Fading) Signal and
NEXT-Adjacent Interference no higher than about 30 dB Stronger than the Desired Signal.
FOX (Ch14) is Adjacent to 65.3 dB Stronger Ch15.
ABC (Ch38) is NEXT Adjacent to 71.5 dB Stronger Ch36.
NBC (Ch33) is NEXT Adjacent to 71.5 dB Stronger Ch35.
I would NOT rely on Antenna Nulling and/or Front/Rear Ratio ONLY to provide the required 40-45+ dB of local signal suppression....strong local signals can reflect off of nearby objects, readily circumventing an Antenna-Only suppression strategy.
A TWO Channel Filter is needed to suppress CDh35/36 by AT LEAST 40 dB, with minimal attenuation on Ch33 and Ch38.....talk to Tin-Lee about your specific requirements.
One Single Channel Filter is needed to suppress Ch15 by AT LEAST 45 dB Attenuation with minimal attenuation on Ch14...which would ONLY be provided by a VERY EXPENSIVE Adjacent Channel Notch Filter....but due to the need to have minimal impact on Group Delay...which is important for Digital waveforms....I don't think they exist at any sort of reasonable price....so receiving FOX may require the use of a Dual Antenna Nulling Trick (which should be used in Addition to the Ch35/36 Filter):
http://www.hdtvprimer.com/antennas/ganging.html
Fol. example presumed the use of two CM4221HD 4-Bay Antennas...but a pair of DIY M4's or FF4's could also be used:
H-Stacked 2xCM4221HD Hacked - NULL BEAM
The NULL would be directed towards strong local stations at 75-deg (re True North), with the Antenna Separation Distance chosen so that ONE of the Two BEAMS is directed towards 105-deg for best FOX (Ch14 on 473 MHz) reception. UNFORTUNATELY, for 30-deg difference between the NULL and the BEAM, the SECONDARY BEAM must be used, with much lower Gain than the PRIMARY BEAMS.....so don't be surprised if this technique is underpowered for weak FOX signals.
Note that the Angle of the Two Beams VARIES with Frequency for a given Antenna Separation distance....ideally, I would insert an RF DPDT Switch (under DC Voltage Control) to reverse the polarity on one of the 300-ohm connections to change between NULLING and normal SUMMING mode:
