1 - 1 of 1 Posts
Hello,
I am in need of a TV tuner card that has the ability through an IR blaster to change the set top boxes channel. SD only no HD going on. Mpeg is ok as the output.
Browsing around looking at Hauppage cards some say they can but the cards don't show a connection where the IR blaster would connect, at best they are for the remote that comes with the card to change the channel on the PC.
To me their claim of being capable of recording from a satellite/cable box is misleading since it can only recoed the channel you are on and so limits it's capability to schedule recordings etc.
I'm using Win 7 64bit.
Any recommendations etc. would be appreciated.
1 - 1 of 1 Posts
