1 - 20 of 39 Posts
Hi All
I like to get some advice on what steps should I take. I presently have the following equipment 3100 and 5900.
The 3100 is no longer getting a signal. I tested by connecting the 5900 in place of the 3100 and get full signal.
I have another 3100 would Bell give me a new card for the 2nd 3100 if I send them the one from the one that is not working? Or am I better off getting a new receiver from Bell is there a discount?
The other question is should I resolve the 3100 before calling Retention?
Thank you in advance.
Joe
Call them up and let them trouble shoot the problem with you. If they can't fix it then tell them you might as well cancel the account you can't afford a new box. They might offer you a free 4100 or credit to buy a new 4100. That's what happened to me a few years back.
Discussion Starter #5
It may not be the card that is the problem. It may be the tuner in the receiver.
You may need a new unit.
I know it's not the card that is the problem. But if I use my other 3100 from storage I will need a new Smartcard. I'm sure it's the tuner because for weeks I would get full signal and then lose the signal and the weather was nice out. Plus the 5900 was working fine in the living room.
The 3100's have been known to have the centre lead tear off the circuit board inside the units, which is a quick and easy repair.
To test for this without opening the up the unit, while connected to your TV and satellite dish, and in the signal strength meter window of the menu, place a small amount of pressure upwards with your fingers on the coax going into the receiver from the satellite dish. The upwards pressure pushes the centre lead down inside the unit, onto the circuit board, if you get signal when doing this, (and it doesn't take much pressure), it can be fixed with a re-solder job.
Otherwise see the Retentions thread at http://www.digitalhome.ca/forum/showthread.php?t=48593&page=43 as you may even be offered a free rental.
Check your signal strength on Transponers 05,13, and 21 ensure they are above 75%, if it isn't the signal is currently to blame (Can't recall where the guide is stored as per transponder) also go to menu 6 1 3 and ensure that you do not have any warnings present in terms of LNB Drift (Highly Unlikely but possible)
Also try doing check switch with Menu 6 1 1 and selecting check switch and then let the receiver finish it, once it is complete exit all the menus and let it come back by itself (Progress for signal) and see if it fixes itself
If that doesn't work and your signal is high enough and you don't have any problems in terms of the LNB or switchs, you may need to clear your NVRAM (Instructions are on this link http://digitalhome.ca/forum/showpost.php?p=409233&postcount=1 )
He said he has a 3100.
Transponder 5, 9, 11, and 17 will not work.
As of this morning, signal strength has increased, and I now get 100% on Transponders 1, 2, 3, and 4.
Try these.
old 3100
i have an old 3100 i got a new 6131 so i deactivated my 3100 and gave it to my son inlaw to hook up on his account . when i hooked it up it has no signal strength but his other does any one know why .its got 100 percent signal strength at my house
Model 3100 problem
My buddy's 3100 stopped working the other day.
I checked it out today.
The problem is simple, it will not stay on.
I tried unplugging it from electricity for 30 seconds, no luck.
With the unit plugged in, I tried a hard reset, I tried removing and re-installling the SmartCard, no luck.
I tried all these tests with the satellite cable disconnected too, still no luck.
No matter what we do, the unit shuts itself off about 2 - 3 seconds after turning on.
Any ideas?
Yep, I agree, it is dead.
That does sort of rule out shorted cable....
This is exactly how 90% of Headend 3100's die. No warning at all, working fine, then you power them down to work on them, gone. Just like that.
1 - 20 of 39 Posts
