I currently have an ADT alarm system, and for a couple of months now have been using the SHAW digital phone service here in Calgary. So far, 2 times (once was hardware failure) the alarm has went off when it should not have. The second was because Shaw was performing maintenance on the 'line' at 1AM and turned the connection off - hence the alarm went off after the phone line 'went down'. Now, if I leave for the weekend, I cannot arm the alarm because if the Shaw line goes down, the alarm will go off and the only ones which will know this are my neighbors - as it obviously cannot call ADT!
I have talked to ADT and they say TS basically - and that the cell module is not available in Calgary.
Shaw says they are working with ADT - but who knows how long before something actually happens.
Is it possible to have the alarm system ignore the status of the phone line while the system is armed? In the same way the system ignores the motion sensor when it is put on stay.
Any other suggestions??
Thanks!
Thanks!
