Edit by 57. Please discuss adding/using an external SATA HDD in this thread. Please also see the following new post:
http://www.digitalhome.ca/forum/showthread.php?t=98929
Hi, new to DHome and Pace 775D. So far all is well with the Pace and love being free'd from commercials!
Thinking about adding an external drive and contacted Shaw tech support. They didn't really have much advise to offer except to email me these instructions from their notes;
8 - Connecting eSATA external Hard Drive to Pace HD PVR
This section outlines the process on how to properly install an external SATA (e-SATA) drive on Pace Tahoe TDC775D.
**Important: Content recorded on the PVR can only be viewed from that specific device. Content can not be transferred or viewed on a home computer or any other electronic device. Do not use an E-SATA from your PC as it will be automatically reformatted when connected to Pace resulting in ALL DATA BEING LOST.
Installation
1. Pace PVR must be disconnected at the time an e-SATA drive is connected.
**NOTE: If an e-SATA drive is connected while the system is running the e-SATA drive will not be recognized.
2. e-SATA drive must be connected utilizing the SATA port via an e-SATA cable.
3. Once connected, the PVR can be booted up. Boot time should not be affected when a properly working e-SATA drive is connected.
4. Once the e-SATA drive is connected and the PVR is powered on, the user will be prompted to format the e-SATA drive. This will mate the e-SATA drive and its contents to that PVR. Formatting of the e-SATA drive will only be required the first time the e-SATA drive is connected to the STB.
5. You must choose “YES” in order to have external eSATA Hard Drive functionality on the PVR, formatting will take 10 to 15 seconds.
**NOTE: Content recorded on the PVR can only be viewed from that specific device. Content can not be transferred or viewed on a home computer or any other electronic device. Moving eSATA to PC will cause an automatic reformat and all data will be lost (vice versa: PC drive to pace).
Reading this forum I didn't find any "approved" eSATA drives, though Western Digital seems preferred, but any drive can be used as long as it's; under 750GB, non USB, 7200rpm 133mb/sec, and conncected with an eSATA crimping cable?
I wonder if I will lose my programming currently on the PVR once I connect the external. Sounds like once installed both internal and external drives are accessed automatically.
Anyone have any sucess/failure with certain drives? Anything else I should be thinking about before going shopping for an external drive?
Installation
