1 - 4 of 4 Posts
Hey all,
I'll be moving at the end of the month and have arranged for ultimate tv to be installed for the new place. I'm currently an MTS wireless & internet (normal high speed) customer with no tv, and I told the dispatcher I would not require a wireless router as I will be using my WNDR 3700. Here are the questions:
1) How many pieces of hardware will I get? Just the stb? Or the stb and a 2 wire unit?
2) My modem as it stands now is the small black unit (actiontec?) and handles the authentication for access. Will the new hardware do the same or will I need to adjust my router?
Thanks in advance.
hey
you will get a stb for ever tv you want to connect and yes you will require a 2wire unit. you can plug your 3rd party router into the 2wire and yes it will handle the authentication as your actiontec is now.
1 - 4 of 4 Posts
