Hi UncleMike, how is the 9241 connected? and can you elabourate on your LNB and Switch setup if possible? You said you have dual lnb's, how was this setup connected to your 9241? something tells me you are not using Dish Pro Plus equiptment but you are trying to use a Dish Pro Plus Separator which will not work for many reasons explained on here. Is this the case?Sorry if I’m in the wrong forum, I haven’t been on here in a while. Hi all. I’ve got a 9242 that I’m going to use to replace a 9241 but I’m having some issues. When I hook up the 9242 I can’t get 82 to come in at all but 91 is fine. Both sats come in on the 9241. I’m running a dpp separator with dual lnb’s currently. Do I have to get a sw44 to run it or is there an easier way I’m not aware of? Thank you.
