1 - 9 of 9 Posts
To get more replies and make this question meaningful, why not add the keystrokes required to obtain this information from the 9242.?
Lo 51
Avg 54
Hi 59
I have been told this is too hot. The 9242 is in an enclosed shelf but open in the front and back.
Air circulates through but I imagine is gets hotter than if it were simply sitting on an open shelf. There is an EHD attached to it also.
I have never had any problems with my 9242 (overheating or otherwise) since I bought it for 299$ almost 2 yrs ago.
Hope this helps.
Yes, I have placed the laptop cooler on top of the unit and it is blowing through an opening outside of the enclosed shelf (back and front).
I consider the enclosed shelf a must because I no longer hear the 9242 fan during quiet scenes. It has been running like this for over two years no issues.
Average 48 maximum 54.
Lo 51
Avg 54
Hi 59
Hope this helps.
These temps are quite similar to mine, and I have seen no strange behaviour.
The unit is located on an open shelf.
High - 59, Low - 50, Avg - 55.
I'm guessing that Bell's programmers modified the Dish software to report temperatures in degrees C, rather than degrees F, but forgot to change the "F" to "C" in the output string.
Even sillier, my 9200s report average temperatures lower than the lowest temperatures.
Here are the current readings from my 3 PVRS, all in the same, well-ventilated closet:
9242: high 59, low 47, avg 52
9200: high 48, low 35, avg 20
9200: high 57, low 42, avg 32
1 - 9 of 9 Posts
