Status
Not open for further replies.
1 - 3 of 3 Posts
If i want to use my 9241 receiver only in my Rv do i need to hoock it up to the 44 switch or run a single wire on either side of the lnb directly into the 9241 receiver.
Thanks anyone.
If you are not bothered with HD Channels, just connect to both sides of the 91 LNBF.
1 - 3 of 3 Posts
Status
